New member Username: Viva_la_bamPost Number: 5 Registered: Jan-06 | whats better 3 10s jlaudio w6v2 or 3 10s jl audio w3v2 on a f150 single cab 04 |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 4680 Registered: Jul-05 | w6v2 |
New member Username: Viva_la_bamPost Number: 6 Registered: Jan-06 | the box could be 4 feet long and 8 maybe 9 inch deph will that be good |
New member Username: 04yellowgtoTuscaloosa, Alabama Post Number: 4 Registered: Jan-06 | make sure you leave room for the speaker depth(check the manual or check online) and make sure there is the right air space and you'll be fine. Also, I would pull up the seat to where it would be with the box and and see if it feels okay. I learned that one the hard way. Used to have an s-10 with two kicker 12's and jl 10's behind the seat. Not fun to ride, but definately fun to listen!!! LOL!!! Hope it sounds great!!! |
New member Username: Viva_la_bamPost Number: 7 Registered: Jan-06 | do i need a lot of air space for the sub to sound good or just a good box |
Gold Member Username: Southern_bassParis, Tennessee U.S. Post Number: 1240 Registered: Dec-05 | 3 w6v2's will sound amazing in a single cab truck |
New member Username: Viva_la_bamPost Number: 8 Registered: Jan-06 | yeah but do i need a lot of air space for the sub to sound good or just a good box |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 1673 Registered: Sep-04 | yes, you'll need the reccomended amount of airspace AND a well built box. check www.jlaudio.com for the reccomended enclosure size. |
Gold Member Username: James1115Wilton, Ct Post Number: 4677 Registered: Dec-04 | also you are going to have trouble finding a amp to power 3 w6's at 2.67ohms. |
Bronze Member Username: MiriamrowlandFt. drum, New york Us Post Number: 31 Registered: Jan-06 | no he is not, he can get a JL 500/1 or 1000/1 to power them hell i will sell him a new 1000/1 for 800?????? |
