Need to find out how to wire two 2 ohm dvc subwoofers and one 4ohm dvc subwoofer to get a 2ohm load?
Username: Lilflippy
Post Number: 13
need to find out how to wire two 2 ohm dvc subwoofers and one 4ohm dvc subwoofer to get a 2ohm load?
Username: Brynm
Prince Albert, SK Canada
Post Number: 165
You shouldn't mix different impedances on the same amp, with these subs you can't get equal impedances on set would be getting more power than the other, that being said witha 2-channel amp it would probably be all right. Wire the two 2ohms at option 2 http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+2+ohms+x+2&image.x=19&image.y=16
and the dual 4 ohm as option 1 http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=1+woofer&WoofImp= Dual+Voice+Coil+-+4+ohms+x+2&image.x=18&image.y=16
just use a 2 channel 2ohm stereo stable amp
