Denis_A Unregistered guest | My girlfriend has a new 2006 Honda Civic and if any of you guys ever seen the dash on that thing, the stock CD player should stay in. So, i'm guessing the best solution to this would be to get a RCA line converter? She's looking to add an amp to power a sub and front components. Do line converters degrade the sound quality much? are there certain brands of line converters that I should be looking at? or are they all essentially the same? any help is appreciated, Thanks |
Gold Member Username: TjmutlowPost Number: 1177 Registered: Sep-05 | Buy a high end, like audio control or the Jl cleansweep. |
Bronze Member Username: Ruxpin20DeTroiT, MIchiGan Post Number: 61 Registered: Oct-05 | yeah the jl cleansweep things look very nice if you have a stock radio, better than getting a krappy rca inverter from meijers at 2 am in the morning....... |
Silver Member Username: B101Queen City, NC USA Post Number: 674 Registered: Sep-05 | that JL is sweet, I like it. but Audio Control & Epic Center been doin it for years. |
Denis_A Unregistered guest | Thanks alot. I appreciate the help |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 371 Registered: Mar-04 | you can save yourself a ton of money and get an excellent quality LOC at www.davidnavone.com. Considered by some to be the best LOC's available. |
