Where i should put my subsonic filter
Username: Dustin3
Tigard, Or U.S.
Post Number: 297
where should i?
Username: Insearchofbass
Post Number: 4282
well if your running a fmod from harrison labs they go in the rca's of the amplifier
Username: Dustin3
Tigard, Or U.S.
Post Number: 298
what? there is a name called "subsonic" and then there are two brackets, one branching off to the left going to a on/off switch and then
on right side it shows a button you turn that goes from 20-50?
should i have this on? and what should i set it at?
Post Number: 4307
is your box ported or sealed if its ported you turn the subsonic just below your ports tune frequency
Username: Dustin3
Tigard, Or U.S.
Post Number: 300
its ported... and my port is tuned to 38 hz... so would i tune my subsonic to 35??
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 851
yes
Username: Dustin3
Tigard, Or U.S.
Post Number: 301
and what about the HPF? i dont have an on/off button for it so should i just turn it all the way counterclockwise?
Username: Dustin3
Tigard, Or U.S.
Post Number: 307
bump
Post Number: 4309
you want the low pass filter on set to about 80 hz or lower depending then the high pass filter should be off as a result the subsonic should be right below the 38 hz tune better to be safe than sorry
