Quick question bout a batcap 800
Username: Rhassler
Gilford, NH
Post Number: 518
Hey, I just got my batcap 800 from www.lightav.com , the guy there was cool, he knocked off a few bucks on the list price for no reason lol..... but anyways, I can just hook this up right? like I don't need to charge it like I would for a capacitor? and what guage wires should I use?
thanks!
Username: Rhassler
Gilford, NH
Post Number: 519
bumpp
Username: Insearchofbass
Post Number: 4305
you wont need to charge it its a battery the alternator will refresh it if it needs any
Username: Rhassler
Gilford, NH
Post Number: 520
ohhh aiight, thanks
Post Number: 4311
yw
Username: Tjmutlow
Post Number: 1057
you need to make sure it is hooked up right though, I ran negative from battery on mine, i think it shows as the prefered way on instructions.
Username: Rhassler
Gilford, NH
Post Number: 521
yup there is 2 good ways, one ok way, and one bad way i think lol
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 1625
they work nicely i have one. i used 4 ga wire but i would just match w/e wire your using. ex 0ga if thats what your other wire is, i wouldnt go smaller than 4ga though.
