Change sealed box with a ported box and NO BASS :-(
Username: Panamanian
Panama cityPanama
Post Number: 178
I had a sealed single box for one subwoofer 10"
While trying to increase my bass i bought another box for two 10" subwoofer, but now PORTED.
Had my 2 channels amp (200w rms x 2) bridged into 500w rms x 1, then i unbridge it with for this new subwoofer for a total of 2 10" subwoofers with my ported box, but I GET NO BASS AT ALL, very little bass. (the same or less than my 6x9).
I know the manufacture was recommened a sealed box, but I thought 2 subwoofer in a ported box would give better bass.
the subwoofers are the same model, both at 330w rms (moved by 200w rms each channel).
WHAT COULD BE WRONG?
thanks
Username: 54danny54
Betsy layne, Kentucky.. USA duh
Post Number: 1504
a leak sumwheres?
Username: B101
Queen City, NC USA
Post Number: 490
just stuff something into the port, like a shirt!
but they sell precut rubber peices to fit certain port sizes.
now why would it be softer than a sealed box?
what kind of subs are they?>
what kind of amp?
Username: Araknid
BOCA , FL U.S.
Post Number: 1531
its ported..... i doubt it has a leak problem lol...
Uh lets see.. do you know what its tuned too? Might be a phase problem also.
Username: Sploosh56
Ohio
Post Number: 1072
did you say that the box is a dual ported box but you only have one subwoofer in it? if so then that's your problem
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 772
Panamanian,
You need to read and learn how enclosures work, and are calculated. No offense but just because you put your woofers in a ported enclosure doesnt mean you will get more or lower bass. It just doesnt work out that way.
A sealed enclosure will give you more bass and lower bass as you make the box bigger. This is true up to a certain point.
A ported enclosure works differently. A bigger box doesnt mean that it will give you more bass or lower bass for that matter. The same goes for the port. A ported box is calculated very precisely, and if you do not follow the guidelines, then you will get a terrible result.
Go read a book about enclosures. Read online at www.bcae1.com. You will not become a guiniess overnight. You will not get the answers you are looking for right away. Sometimes it will take you years to figure out certain things.
Yes it seems like such a simple thing. You have a speaker, put it in a bigger box, WHALLAH, BOOM. Ha Ha it doesnt work that way.
If the manufacturer recommends that a speaker be used in a sealed enclosure it may be because there is a reason for it. Like I said, go do some reading, and do not build something before you fully understand the process. This way you will not have a problem.
Panama cityPanama
Post Number: 180
Thanks guys for answering, one of the wpeaker was wrong wired, I didnt know one could affect the other, now I get mucho bass.
gracias
Panama cityPanama
Post Number: 181
also could someone technically explain me why misconnecting the wires make the subwoofer or any speaker to be weaker?
Username: Tdbdadrummer
Post Number: 959
Did you accidently put the - into the + terminal or vice versa?
I did that once and almost peed myself laughing after I figured out what had happened, because my wire was gold for both + and -, and the markings on the insulation were small, so I didn't notice.
What you'll notice is the woofers pop out, and like you said, very little bass no matter what you do. Try switching around the wires at the terminals.
Username: B101
Queen City, NC USA
Post Number: 494
you wired your subs out of phase.
you dont want to do that no more.
okay
