(Noob question) Can i change a ported box into a sealed one?
Username: Panamanian
Panama cityPanama
Post Number: 179
I bought a ported box, but i feel the bass sucks (NO BASS), can i change it or transform it or cover the 2 holes to make it sealed?
Or do you know if there exist covers to the holes so the entire box becomes sealed?
Also if that were possible, would it be sound the same?
gracias
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 837
yeah, sealing the ports will make the box a sealed box, but make sure the volume is within reccomendations for the sub. ported boxes are generally larger then sealed, which can affect the sound.
Username: Graphix1
Santa Rosa Heights, Arima Trinidad & T...
Post Number: 570
Yep^^^^
What r u talkin about......usually ur supposed 2 get more bass(louder) with a ported box.....i dont think sealing it will solve your problem
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 826
yeh a sealed box will make it quieter.. there must be something else wrong
Username: Rzarector
Post Number: 827
i remember him buying a SONY XPLODE sub so thats the problem right there -lol
yup that would do it... more power.. i think sonys can take 25wrms befor they XPLOODE
