Wiring six 4ohm DVC sub to dual output Mono amp (Orion 2500d)
Username: Invictuz
Seattle, Wa Usa
Post Number: 174
Question: What Ohm impedance will i have from wiring six 4ohm DVC subs to an Orion 2500d.
The 2500d has 2 outputs (two seperate positive and negative speaker connections even though it is a mono amp)
So if i were to wire six 4ohm DVC together i would come up with an impendance of .33 ohm (if connecting to a single output mono amp).
HOWEVER
Because the amp had dual output i have to wire three speakers to a connection.
Three 4ohm DVC subs wired parallel and parallel give me a .67ohm impendance.
.33ohm is too low.
.67ohm seems to ok for daily drivers (see link below)
I called and email DEI but have not received an answer in 2 weeks.
http://www.caraudioforum.com/vbb3/archive/index.php/t-232594.html
Username: Tjmutlow
Post Number: 788
orion, dei will not tell you to run it at that load, 1ohm only....liability issues.if you wire three of them series/parrale it has a 2.666load, then wire the other three the same way, then series each set together.
Username: Invictuz
Seattle, Wa Usa
Post Number: 175
i am trying to get a load of between .5 and 1 ohm.
anyone ever wired 6 DVC 4ohm subs to a dual output mono amp
Username: Qcsfinest
Charlotte, North Carolina
Post Number: 139
you can six dvc subs to 1.3 Ohms (series) or .33 in parallel...
http://mobile.jlaudio.com/support_pages.php?page_id=161
Username: Qcsfinest
Post Number: 140
*you can do six*
sorry about that.
Username: Invictuz
Seattle, Wa Usa
Post Number: 176
yes, i am aware of that it can be done.
My question is "what is the impedance when hooking six 4ohm DVC subs up to a DUAL output mono amp (such as the Orion 2500d)?"
In other words i have to hook three 4ohm DVC subs to one amp output and three 4ohm DVC subs to the other amp output.
Will this affect impedance as i have to wire parallel/parallel in two sets of three subs.
Username: Tjmutlow
Post Number: 794
That amp has an internal feature that auto bridges the amp, it only sees a mono load. and I would not run that at .5 for long, it is not made like the old HCCA amps.
Username: N2audio
Lawrence, Ks USA
Post Number: 143
those two sets of connections are parallel inside the amp. Schematically it's the same connection, just a y at the end so you can easily run more than 1 speaker lead.
The least confusing way imo would be to wire the subs in two sets of 3 - each set series/parallel for 2.67 ohms. Then 2 sets of speaker leads from the amp to each set of 3 subs - that parallels them for 1.33 ohms.
Username: Invictuz
Seattle, Wa Usa
Post Number: 177
Thank you Opti...thats what i was looking for regarding how the 2 sets of outputs were wired...
my goals is to hit something between 1 and .5 ohm...
in theory could you wire all six subs to 1 set of outputs (leaving the second set unused)?
Username: N2audio
Lawrence, Ks USA
Post Number: 154
yeah, just like the JL diagram - 2nd from the bottom.
Username: Invictuz
Seattle, Wa Usa
Post Number: 182
Username: Invictuz
Seattle, Wa Usa
Post Number: 184
thanks again
Username: Redbone15367
Mo U.S.A.
Post Number: 110
OPTI
are you sure about the leads being parallel inside? I just got mine (used) and no paper work with it. I'm running a re mt 15 on it(dual .7 ohm.) and it runs it pretty hard, but the amp doesn't get hot, but will cut out on realy high volumes, for a split second.
Username: Tjmutlow
Post Number: 928
it bridges it internal, and if you do not have enough voltage your going to have it cut out.
Mo U.S.A.
Post Number: 112
i have 2 alts and 2 bats. 1 just for the amp. that would be running at .35 ohm
Username: Tjmutlow
Post Number: 931
amp is at to low of impedance then...
Mo U.S.A.
Post Number: 113
I think I will change to series see if that helps this is only half of what i'm putting in.Upload
this is all unfinished. The metal is 2 24g sheets glued and then renforced together. made a big differnce on sound. will have it meterd on tues.Upload
Username: Invictuz
Seattle, Wa Usa
Post Number: 191
Red: how hard was it to install the second alternator? i have been considered removing my AC and putting a second alternator there...
also: are you saying your speaker box is build of metal? did you line the interior with anything? how does the bass sound?
Mo U.S.A.
Post Number: 116
the box is 3/4 paricle board, I just made a scoop for the box. I did duble up on thickness of the wood. glued and screwed heavy. I had tomuch noise from back of the cab, and the glass wanted to move tomuch. By doing this I lessend the presser lose, or redirected it up front.It sounds great. better than without it. The metal is renforced(braces) and expanding foam. As for the alt my ac never worked so out it came. I welded in 1 brace for it changed belt sizes and it works. Do you have a chevy 350?Upload
It's not that hard if you have the tools
Username: Invictuz
Seattle, Wa Usa
Post Number: 200
i am not a welder..so will look for an adapter bracket.
It s jeep ZJ (318ci / 5.2liter).
It doesnt appear that it would too difficult to swap an alternator with the AC...and i already have 2 belts sizes ...standard and 1 to bypass AC in winter for gas mileage)
thanks
