Do i have room for good subs
Username: The_great
Post Number: 28
i got a f150 and i need 2 know for da subs does it need a lot of room or just da right box
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 667
is it single cab ? extended cab?
Username: The_great
Post Number: 29
single cab
Post Number: 677
alright i got a single cab f150 too. ok what i think is everyone trys to fit 2 12's or whatever but your best bet is going to be 2 10's..you probably wont have to worry bout them fitting as bad as the 12's..sure you can fit some good subs back there and there just right there so they are going to be loud to you in the cab....whats a price range and are you looking for spl ? sq ? sql ?
Username: The_great
Post Number: 30
sql and i was thinking of getting 3 10inch kicker cvr and a memphis 1100 or maybe i will wait for da the new kickers
Post Number: 691
behind the seat ? ive saw people even take out the middle console and put them there
Post Number: 692
http://cgi.ebay.com/ebaymotors/2001-Ford-Lightning-2WD-low-mileage-Immaculate_W0 QQitemZ4604171470QQcategoryZ6219QQrdZ1QQcmdZViewItem
check this out
Post Number: 693
i would probably wait until kickers new stuff comes out...get a couple of them if you like them or if not the cvr's should be cheaper then
