Hole in my sub
Hey everybody, I feel pretty much retarded. I was putting my subs into my friends bandpass box to see how theyd sound, and its a tight fit so i had to secure it at a hard angle. So to the point, i was screwing a screw in and it slipped and went right through the rubber surround. I havent tried to see what it sounds like, but i was hoping you guys might know about some kind of epoxy or something to fix the tear. Thanks
Username: Gavbo211
US
Post Number: 148
i did that too one time. i got sumthin from wal-mart.. i cant remember the name but it was in vibrant silver tube. sry i can remember but just look for the silver tube u cant miss it lol.
Username: Frkkevin
Fort Worth, Texas US
Post Number: 149
clear silicon on the inside of the rubber where the whole is will do the job.. ive fixed a few subs with that problem
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1962
it's a common mistake. it's a great idea to always use a guard on your drivers.
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=340-076
Username: Jonathan_f
GA USA
Post Number: 5404
Fingernail polish works, too.
Username: Six
Flint, MI U.S.A.
Post Number: 317
Would fingernail polish eat away foam surrounds?
