Help with 3 subs!
Username: Legendx
i have 3 10" MTX subs, they are single voice coil and 4ohm stable each. i was wonder if there is a way to hook them up to one amp. i kno you can hook them up to a 1 ohm stable amp but is there anyway i can hook them to a 2ohm monoblock. if so how? thanks
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 4260
u can only make a 1.34 ohm load or 12 ohm load so ur amp will have to be 1 ohm stable. But if u plan on running it at 12 ohms (which is crazy)ur amp will be stable at 4, 2, or 1 ohm mono
Username: Legendx
i heard from a local car audio store that you can hook it up to a 2ohm mono. the guy said i had to hook up 2 series and one parallel...or viceversa...i cant recall exactly, but it somwhere along those lines.
Username: Tdbdadrummer
Post Number: 953
http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =3&impedance=SVC4
Check it out.
Username: Fandim
Reno, Nevada United State...
Post Number: 565
Tom, that would NOT be a good idea.
If you have two subs in series, they're presenting an 8 ohm load, then wire the one in paralell, and then you're presenting a final of 2.67 ohm load.
However, the two speakers in series, will only recieve 1/3 of the power, while the single sub wired in parallel to the series connection, will recieve 2/3 of hte power.
So if you are using an amp that puts out 300 watts at that impedance... ... and your setup is like this..
Then you're going to end up with this...
So it's a bad, bad idea. :-) And it'll sound like crap, too.
Username: Fandim
Post Number: 567
You could try running it in 1.3 ohm, some amps work at a lower impedance than they're rated...others dont.. (For instance I'm running my hifonics 1605D at a .7 ohm load just fine)
Username: B101
Queen City, NC USA
Post Number: 447
^^ lol
like Seth Lowe said, all you will be creating is a Voltage-Divider. You will be giving more power to 1 sub..
They all neeed even amount of power.
If you do it, u risk blowing 1 alot faster.
