New member Username: Vc3Post Number: 10 Registered: Jan-06 | What amp would be good for 3 JL 12W6v2? Thanks |
New member Username: SubsonicDunn, N.c. Post Number: 1 Registered: Jan-06 | a jl 1000/1 |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 4093 Registered: Jul-05 | yeah^^, kicker sx 1250.1, Phoenix Gold Xenon 1200.1, etc |
New member Username: SubsonicDunn, N.c. Post Number: 2 Registered: Jan-06 | yeah kicker sx 1250.1 and sh** .(JL 1000/1 ) same power from 1.5ohm to 4 ohm and from 11v-14.4v same power! kicker needs 14.4volts to get 1250watts@1ohm three JL 12w6v2 wired to 8ohm each will =2.7ohm load |
Silver Member Username: TjmutlowPost Number: 946 Registered: Sep-05 | that amp will not push 3 12w6 correctly |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 4106 Registered: Jul-05 | "kicker needs 14.4volts to get 1250watts@1ohm" 4 u to have such a nice system ur are sounding like a newb, it will reach 1250+ rms at 13.8 volts, btw i have 4 and love them to death. Also u do realize that the 1000/1 will only put out 500 watts @ 8 ohms so u will be seriously underpowering them |
Bronze Member Username: Vc3Post Number: 11 Registered: Jan-06 | so if I were to get the kicker sx 1250.1 amp how much rms would each sub get? Thanks |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 250 Registered: Mar-04 | --"u do realize that the 1000/1 will only put out 500 watts @ 8 ohms so u will be seriously underpowering them"-- He said 8 ohms each - I think we are to assume parallel wiring from there to = 2.67 The 1250.1 is a bad choice for this application - you'd be paying for 1200w+ and only able to get ~500 from it. |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 1782 Registered: Oct-05 | optidriven how do you make the letters darker like that? |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 253 Registered: Mar-04 | basic html code [b][/b] [i][/b] etc. use <> instead of brackets. |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 254 Registered: Mar-04 | I guess I could have just enabled html code ![]() bold = <b>text</b> italic = <i>text</i> not sure what other tags work. It doesn't seem like very many. |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 255 Registered: Mar-04 | **disabled |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 1783 Registered: Oct-05 | thanks |
Silver Member Username: UcfsaxmanOviedo/orlando, Fl Post Number: 515 Registered: May-05 | the JL amp would be the best but wouldn't that kicker amp be closer to 1000 or like 900 watts @ 2.67 ohms |
Bronze Member Username: Vc3Post Number: 13 Registered: Jan-06 | is there any amp i could get to fully power them or should I just forget about the 3 subs |
Silver Member Username: TjmutlowPost Number: 961 Registered: Sep-05 | you could run the 3 on that JL, the optimum power for those subs is about 400-500w per sub, after that your heading into the danger zone for those subs(JLw6 and w7 can be power sensitive). i wouuld run just 2 of those on the 1000/1 |
Silver Member Username: N2audioLawrence, Ks USA Post Number: 260 Registered: Mar-04 | --"wouldn't that kicker amp be closer to 1000 or like 900 watts @ 2.67 ohmsThe kicker's 1250"-- Not likely. OCS has it as 1250w at 2 ohms, which isn't correct. It's actually 1250w at 1 ohm, 625w at 2 ohms, so right around 500w at 2.7. Even considering Kickers are under-rated it couldn't do much more than 200w per sub. |
Silver Member Username: RedlinerWilmington, Ma Post Number: 507 Registered: Jun-05 | y not just get 3 500/1 if you really want those three subs |
Anonymous | eagle dont listen to chauncey hes just trying to get his post count up. Like opti said that kicker its a BAD CHOICE. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 4146 Registered: Jul-05 | who cares about getting there post count up.lol, if u care about post counts so much why not register and post as much as u want |
