TS-W256R
Deicide
Can anyone tell me how much rms this sub can take? Cos i looked at the pionner site, can't find it, and the only 2 other sites is bestbuy and futureshop,but they say that its 350wrms and 350wmax... Is that possible? Any help would be appreciated, Thx
Username: Tjmutlow
Post Number: 894
well the 256c/dvc is 700max, 350rms, are you sure it is a 256r Is that a single 4ohm sub, if so, i would use no more then about 400w to it.
