Battery in the trunk
Username: Whassupejg
Fairless hills, PA United States
my 06 cobalt has the battery in the trunk....im not sure so i want to ask... is it ok to use the same ground as what the battery is grounded 2...i dont think it will do anything but im not sure...plz help
Username: B101
Queen City, NC USA
Post Number: 317
yes it is okay!
Username: Fandim
Reno, Nevada United State...
Post Number: 561
Eric, it'd actually be even better, to simply make your ground the negative terminal of the battery.
By using a chasis ground, all you're doing in reality, is connecting the ground to the negative post of the battery, anyways, just through the chasis/ground wire. So if you want to eliminate un-needed resistance, just use the post instead. :-)
Seth
