Which amp is better?
Jack Brian
I have 2 12inch alpine type r and i wanted to know which amp i should get. Should i get hifonics bx1000d and wire it to 1 ohm for 1000 rms or should i get the hifonics bx1500d and wire it to 2 ohms for 1000 rms.
Any suggestions would be appreciated.
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 507
the hifonics bx 1500d
Jack Brian
is it a really big difference?
Username: Do_em_dirty816
Kansas City, MO USA
Whats the rms on those subs... Personally I dont think its a big difference but using the bx1000d you would prolly get the max power out of that amp at 1ohm but you dont know for sure if that amp puts out the power it says. To be safe I'd go with Casey on this one because when you upgrade your subs you might still have spare power with your amp. ;)
Username: Kirbdog22
New Bern, North Carolina USA
Post Number: 140
what is the impeadance on those subs
because that is what depends on what you set your amp:
for example lets say the impeadance on your subs is 4 ohms then u would want to wired your subs in parallel and set your amp at 1 ohm mono.
but if your subs are 2 ohm then u would have to set your at 2 ohm in parallel
