Sony cdxm630 wont work
Username: Bobbydavro
lately my m630 have been playing up and the inside display and interface is not working. i consulted the troubleshooter and it said press the reset button now its fooked. Face will not close, ne ideas pls.
stoboy404
try checking ur inline fuses if u have any or check to see if ur 12v wire r hooked up correctly
Username: Illuminator
Post Number: 2444
It sounds like the flex ribbon cable finally wore down. You can get a replacement cable from the CDX-M630 OR the CDX-M600. Both will work fine.
