I think i blew my sub? need help
Username: Steve_collins
ok so i have a sub and it was playing fine. there was no distortion or anything. then all of the sudden it just stopped playing. i tapped the front of it lightly and it started to play and then quit again. it has not played since so what is the problem and how do i fix it
Username: Killerzracing71
Fredericksbutg, Virginia United states
Post Number: 248
check to see if a wire is loose
Username: Young_james
Post Number: 510
The same thing happened to my old sub. I had mine checked out and discovered that it was toasted. Sounds like the same thing, because whenever I would pust on mine, it would start, then when I let it go, it stopped. I'd say it's blew, but still check all wires first tho. btw, what kind of sub is it?
Where are you from? I know a Stephen Collins, not sure if it's you or not
