Jumper location for Alpine Type-X????
Username: Grat81
Carbondale, IL USA
Post Number: 20
Hi Guys!
I was wondering where the jumper should go if I want to wire my alpine type X dual 4-ohms to make a one ohm load.
The manual does not specify how to do this. The only option for one amp and two subs is the 4-ohm configuration and the jumper goes in the middle slot. There are three slots for jumper placement.
I was wondering if any of you were familiar with these subs and where I should place the jumper for a one ohm load? (or if i should just leave the jumper out?)
thanks guys :-)
-G
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 3688
do u have 2 or 1 sub, i use to have 1 and if u only have 1 u can only wire it to a 2ohm load.
Username: Tjmutlow
Post Number: 777
you have posted this before? or someone has not to long ago....
Username: Grat81
Carbondale, IL USA
Post Number: 21
no, i haven't posted this before. I have 2 subs, going to an amp that can handle one ohm mono. I'd like to wire it this way. If anything, I'll wire it like I would wire any normal dual-voice coil sub and see what happens. I think it should work without the jumpers in there at all.
-G
