How much power is this putting out bridged
Username: Reloaded
Mebane, NC U.S.A
Post Number: 77
Power Acoustik GOTHIC OV2-1200
http://www.shopping.com/xPF-Power_Acoustik_Gothic_OV2_1200
because I have it on a 15" memphis 15-PR154 250wrms and 500wp , I have it hooked up and its slammin . but im afraid of that there is too much power going to it. Ive had a few people tell me that the sub can handle it and that its underated. I have the gain all the way down so will this be fine.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 3627
is the amp 4 ohm stable or 2 ohm stable
Post Number: 3628
@ 4 ohms it should be 500 rms, and @ 2 ohms it should be 600 rms.
Username: Reloaded
Mebane, NC U.S.A
Post Number: 79
2 ohm stable, and sub is svc 4ohm
Username: Reloaded
Mebane, NC U.S.A
Post Number: 80
but do you think its too much for my subwoofer? The guys at the shop said it should be fine. And having the gain down and not peaking the system out by turning it way up will help right?
Post Number: 3629
well since its svc 4ohm, u are running it at 4 ohms.lol, im almost sure pa is overrated so u should be fine
Username: Reloaded
Mebane, NC U.S.A
Post Number: 81
you mean underated right? and the sub will be fine cuz dang its dropping pretty hard . I gotta get alot of dynamat
Username: Reloaded
Mebane, NC U.S.A
Post Number: 82
o nm your talkin about the amp lol. well I got it for 128 almost brand new . Its decent I suppose , not the best but it looks nice and is powering my system so it will do.
Post Number: 3630
no the amp is overrated. the sub should be fine as long as u dont get crazy with the volume not the gain
Username: Reloaded
Mebane, NC U.S.A
Post Number: 83
I will post pics of my install soon . Its in a memphis vented enclosure .
Post Number: 3632
that would be nice.
