What to set the Subsonic Filter at?
Username: Yamahabanshee1
Paulding, Ohio USA
Post Number: 275
What should i set my subsonice filter, gain, and that other 1 at? My amp is Audiobahn A8002T amp pushing 2 12" Fusion PowerPlants in a ported box.
Username: Dustin3
Tigard, Or U.S.
Post Number: 144
just put the gain where it sounds right. i have that same amp and i have it around halfway.
where it blends in with the music and the speakers
Paulding, Ohio USA
Post Number: 278
what about the SSF?
Los Angeles, CA USA
Post Number: 1483
subsonic filter should be set to whatever your ported box is tuned to.
what actually does the subsonic filter do??
Username: Tdbdadrummer
Post Number: 827
If your box is sealed, it's not a big deal, just turn it off.
Set your LPF to between 80-85Hz though, no matter what.
Paulding, Ohio USA
Post Number: 280
ok thanks fellas!
