Will these little dents in this cone effect the sound?
Username: Palanza
Post Number: 14
Ok, inside the kappa perfect cone, there are 3 little dinks in the alumnium. Not holes or anything, they arnt deep at all, just 3 little small dents. Check the link to see a picture of where they are. Will these harm the sound quality of the speaker?
http://img328.imageshack.us/img328/4779/kappaperfect3ul.jpg
Username: Palanza
Post Number: 15
I dont have a digital camera or i would take actual pictures. I'd say they are roughly 1/16th wide, 1/8th long and like 1/64th deep.
Username: B101
Queen City, NC USA
Post Number: 166
if its not a hole, and just small dents, then it should not affect your SQ!
Username: Southern_bass
Jacksonville, Florida U.S.
Post Number: 246
i had some small dings in some old subs of mine , it didnt affect them any
Username: Vinnyqh
Portland, OR
Post Number: 116
are they jsut little dents? anyways, that's jsut the dust cover, doesn't affect sound at all, jsut make sure youdon't poke holes through it.
Username: Palanza
Post Number: 16
Yeah, just little dents. No holes. I was being stupid and i pushed on it very slightly with my finger nail (forgot it was made out of aluminum)
