DEH-P8MP help please
Casey O
ok my P8MP just started freaking out... it always thinks there is a CD in it... as such the brackets which lower the CD so it will be played are staying down not allowing me to insert a cd easily... i can put a cd in by manually raising them and putting it in, but then when i tyr to eject it they will raise for a second push it like 1cm out then lower and the cd will be stuck and ill have press eject again so it will lower and raise itself so i can try again... IS there any solution to this other than sending it back?
Ohh Sh!*... I'm having the same problem. Altough this problem happens intermitently it still freaks me out and I've only had this deck for about 6 months. Help PLEASE!!!!
I have the DEH-P8MP can someone PLEASE tell me how to change the settings to 60W mode? Please be specific.
