Type-R box volume argument.
Username: Hellyhans
Post Number: 19
hey people.. well I ordered my 1 10" box and some people for telling me that the specs given by alpine to build a sealed box would make it sound like crap
They recommend:
gross volume range :0.5-0.8
optimum sealed box:
gross internal:0.65
Net internal 0.6
Now my needs are for a sealed box as I don't want a bigger box in the truck,I do not want SPL, iam more SQL, I listen to metal/rock,not hard bass hitting rap.
What do you people think and recommend?
Thank you
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 795
go with what alpine recommends.. i built a sealed box for 2 12"s at what alpine said was the optimum sealed box and it sounded great
Username: Southern_bass
Jacksonville, Florida U.S.
Post Number: 112
sealed box for sure with what you're wanting
Username: Tjmutlow
Post Number: 458
They bulit the box wrong then, make sure you have the correct internal volume, including speaker displacement etc.
