Ported box
Username: Steven1234
Rahway, NJ
Post Number: 23
can u use a ported box to get SQ. Or sealed boxes give u the best SQ and if so how come there better for SQ rather then ported.
Username: Dustin3
Tigard, Or U.S.
Post Number: 120
because sealed has a tighter bass and doesnt allow the air to move out of the enclosure = better bass response.
a ported box is for spl or how loud it gets. each sub sounds better in one of these 2 enclosures, dont go bandpass.
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 794
https://www.ecoustics.com/electronics/forum/car-audio/183170.html
read jonathans response a few posts down
Username: Jonathan_f
GA USA
Post Number: 5115
Better yet, read this:
http://www.hometheaterhifi.com/volume_5_2/cmilleressayporting.html
Personally, I think a well designed ported box can spank any sealed in SQ with an added efficiency advantage as well. Of course, that is dependant on the driver itself, as the suspension of the driver will determine what type of box the driver works best in. TLs and AP membranes are my favs for SQ, then ported, then sealed. There are a lot of misconceptions about ported boxes, mainly because they're more difficult to design and implement than a sealed box is. There are also a bunch of crappy ported boxes at your local Best Buy or Circuit City, adding insult to injury.
