0/1 Gauge Wire
SeanC31
Where can I get a tool or something to strip it? Also, where can I get a tool to crimp it? Thanks alot.
Username: Redliner
Wilmington, Ma
Post Number: 169
just use a knife to strip it and use a vise to crimp it
SeanC31
ok cool for the stripping....but I dont have a vise so what else could i use..Thanks
Username: Redliner
Wilmington, Ma
Post Number: 170
umm do you own a pair of channel lock pliers you could try that it would be hard though but besides that you might have to go to someone lese cause i used channel locks and a vise so i dont know
Username: Tjmutlow
Post Number: 434
Since no vice, I put it on ground take a heavy hammer and do it that way, then i cover the ends with plastic cpas or tape.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1808
the hammer idea works....i should know :-)
i used a hammer, welding lugs, and heat shrink.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 687
hammer and center punch works great. yeah, make sure you cover the ends with heat shrink tube or tape like suggested above.
