Place To Get Big 3 Wires
J Dub
wud up.....can u tell me a place to get my big three wires....thanks
Username: Fandim
Reno, Nevada United State...
Post Number: 516
Anywhere that sells the appropriate wire in the gauge you want to upgrade them to?
Username: Fandim
Post Number: 517
Sorry to clarify my above post.
The big 3, are just simply wires that you can add to (no reason to replace all together) your current setup. You just need some ring terminals, a connection for your battery (assuming you dont already have one w/ an extra input), and a couple screws/bolts.
So really any car audio shop, or any other place that sells wire etc.
Username: Geekbike
Post Number: 405
KnuKonceptz.com sells complete kits for a reasonable price.
