2 12"s or 1 18"??
Sup every 1 in everybodys opinion which would you think would sound better 2 12" subs or 1 18" sub?? Thanx for your opinions...
Username: Lexuscoop
Post Number: 292
why type of subs?
Username: James1115
Wilton, Ct
Post Number: 4358
it depends on the sub and the enclosure and the car and the amp ect lol
Username: Lexuscoop
Post Number: 297
and the HU, the wiers, so much depends on the subs.... its like not even funny
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 430
if your looking for straight sound quality then 9 times out of 10 the 12's will sound better. but it really does depend on the subs as was mentioned above.
Username: James1115
Wilton, Ct
Post Number: 4366
it actually depends more on the amp and enclosure then the sub as Sean has tested many times with low end 6 in mid bass and gottten great results. The damping factor of a amp plays a large role in control over a woofer.
Username: Swervinburbin
Bronx, New York
Post Number: 17
Most likely the 2 12's will sound better.
