Some questions about a component install..
Username: Palanza
Post Number: 10
So, I'm assuming that just like subwoofers, component speakers need to have the front and back of the speaker indiviually sealed correct? Like an enclosure, just inside ur door? Also - is it recommended to put some dampening material between the speaker and the door?
Username: Palanza
Post Number: 12
Oh, and I've heard that the best location for imaging is to design a kickpanel for ur car - I'd have to build it though, cuz I'll be dammed if I pay 100 dollars for it lol.
Username: Vinnyqh
Portland, OR
Post Number: 93
100 bucks for kickpanels? that's cheap! If you want the best bass response then you would glass it into your doors. If you don't have time/patience/money then best choice would be use like some sort of sealent to the door.
