Amp for two RE SX
Username: Demon_pride
Crowder, Oklahoma USA
Post Number: 10
I'm buying two RE SX 12's and I need to find an amp to power both of them. I want to go with a single amp.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1733
http://www.ikesound.com/product-product_id/2425
or
http://www.ikesound.com/product-product_id/2465
those would make a decent budget amp...they put out ~2000wrms @ 2ohm.
but if you have the cash...i would look at a kicker kx2500.1.
Post Number: 11
Isn't that a little too much power? I'm putting them in a single cab truck and thats kinda pushing it because I'll never have a chance to push them hard enough without busting my windows or my eardrums.
Post Number: 12
bump
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 2859
there very tough subs they should be able 2 handle the 2500.1
Post Number: 13
Know where I can find the 2500.1 real cheap? And how should i wire them? Series or parallel or both? I don't totally understand DVC sub wiring yet.
Post Number: 14
No eBay... i just don't trust it. I found it for 800$ on onlinecarstereo. If i cant find it cheaper ill get that.
Username: Rovin
Trinidad & T...
Post Number: 3575
just google the product no
SX subs are 2ohms DVC
wiring guide
http://www.the12volt.com/caraudio/woofer_configurations.asp
Username: Thigpen
RVA, Va Usa
Post Number: 334
you could get 2 re 12.1s for about 380-390 shipped a piece from RE, then wire each to 1 ohm. would be overpower each by about 300-350 watts tho
you could find 2 1000 watt amps that would cost you less than 800 combined
Username: Killerzracing71
Fredericksbutg, Virginia United states
Post Number: 174
Protection: T,S,D,R,O,L
what do all those protection things stand for
Username: Skies
Courtenay, British Colu... Canada
Post Number: 29
T - Thermal
S - Short
cant remember the others at this time..gettin pretty late
