Seismic 12" Subwoofers
Username: Atoneman
ABQ., New Mexico USA
Hello my second post here. Just call me Atone.. I know very little of these speakers. Before I make a decesion to buy these speakers can I get an honest answer here? This is my first time buying speakers and I don't want a bad deal. Here are the details and price
Two 12" Seismic Audio Subwoofers
40 oz magnet
600 Watts Power
Frequency Response: 30-500
Sensitivity: 92 db
4 Ports
Air Tight Plexiglass
Tinted Yello
High Quality Speaker Wire Terminals
15" tall -- 30" wide -- 15.5" deep
Also includes a neon kit.
Neon lights already installed around speakers
Hand held switch for lights.
On/Off/Flash switch
Min-Max knob for light as well.
Here are the page(s) showing speakers..
Side view
http://awesomespeakers.homestead.com/files/G1282.jpg
Top Corner View:
http://awesomespeakers.homestead.com/files/G1284.jpg
Top View:
http://awesomespeakers.homestead.com/files/G1281.jpg
-Atone
i dont care much about the yellow but that just my opinion, i see that the box is seperated inside witch well help with loudness and sound but tell me what are you aiming for in a car audio system?
Username: Atoneman
Looks like I forgot to list the price. These speakers are going for $200.00.
Username: Atoneman
I'm aiming for something that bumps real well. An Audio system that produces a clean, crisp sound. The yellow kinda took me off also, but I can live with that if it's a great steal for $200 ya know. But, pretty much looking for something that just jams.
-Atone
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2350
never heard of the company who makes the drivers
that yellow is hideous
the plexiglass looks like it's 1/4" which isn't nearly heavy enough for a good box. you need at least 3/4" to 1" lexan for load bearing walls of a speaker box to resist flexing.
I'd spend a little more and buy a pair of Adire Shiva 12" or Kicker CompVR 12" for ~$200-$250 then spend $50-60 and build my own box for them, sealed or vented.
Username: Glasswolf
Post Number: 2351
by the way that enclosure is bandpass, and won't hit very deeply. Loud as heck, but not deep.
Username: Atoneman
Thank you very much Glasswolf. But for the $money$ on these do you think they are worth $200?
Username: Glasswolf
Post Number: 2357
not really, but I won't buy cheap crap just to "get by"
I'd rather save up and get decent gear that'll last.
just my outlook.
everybody has different opinions.
Username: Atoneman
Post Number: 7
Thank you Glaswolf, your helping me. This is why I'm posting. I don't want to buy cheap crap just to get buy, I work hard for my cash, and I want a nice system. What about this box, I been also looking at this box it's a 10" though.. It's a
AUDIOBAHN ABP10T DUAL SUBWOOFER BOX WITH 10" SUBS NEON
High Quality MDF Construction
Spun Aluminum Venturi Ports
3/8 Inch Plexiglass Window
Blue Interior Neon Lighting
Mirrored Interior Panels
Dual 10 Inch Molded, Texture Injected Poly Cone
50 oz. Strontium Magnet
2 Inch 4 Layer ASV Voice Coil
Bumped Back Plate
Extended & Vented Pole Piece
Gold Binding Post Terminals
Power Handling: 600 Watts RMS
Peak Power: 1200 Watts !
Sensitivity: 101dB
Frequency Response: 30Hz - 150Hz
Impedance: 4 Ohm Stereo
Dimensions: 11.75 Inch (H) x 25.75 Inch (W) x 13.75 Inch (D)
Pictures
http://www2.freepichosting.com/Images/421447150/6.jpg
http://www2.freepichosting.com/Images/421447150/5.jpg
http://www2.freepichosting.com/Images/421447150/4.jpg
It list for $399 but saling for $150.00
What do ya think about these Glass??
-Atone
Username: Vipersbyms
Post Number: 33
not a fan of audiobahn, and glasswolf will tell you the same thing, they dont have good sq. however, they are a step up from the first set of subs you posted. how much are you willing to spend on subs? as glass mentioned before, those subs are also in a bandpass box so you wont have that deep or low sound. the bandpass will help give the subs a better sound. my brother has 2 10" earthquakes, pos, in a bandpass and they dont sound 1/2 bad, loud but not deep at all. would be awefull if they were in a sealed box.
Username: Atoneman
Post Number: 8
Well at the moment I can spend anywhere between $250-$300, and I would like to find subwoofers that already are pre-installed in a box. Thank you for your honest input their Kevin. As you may notice, I know very very little about car audio stuff. I never was big into this, but now I'm looking and now seeking advise.
-Atone
Post Number: 37
just like glasswolf said before, kicker comp vr's. u can pick them up on ebay for $150 for a pair shipped. they're really good subs for a great price. u find them at an online store for a little more. then u can just buy a box, and wiring the subs is very easy. wiring them is also very easy to mess up if u dont know exactly how to do it. so just ask us when the time comes, and we will tell u how to wire them step by step.
Username: Glasswolf
Post Number: 2377
I was just thinking that.
two Kicker CompVR 12" subs (2+2 ohm DVC models)
then search eBay for "kicker comp vr box gold"
you'll fine a slot vented box built of 3/4" MDF, carpeted, with gold terminals designed just for those subs. they sell for about $40-50 for the box
the subs are about $99 each new.
that'd be ~$250-300 US.
and you'll be very happy with the outcome.
they'll want ~300wRMS each, so a Kicker KX600.1 is an ideal amplifier to match with those two subs.
with two 4+4 ohm DVC subs you'll get a 2 ohm load which is ideal on that amp.
Username: Glasswolf
Post Number: 2378
in fact this guy sells quite a few of these boxes.
here is one:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39777&item=3093583975&rd= 1&ssPageName=WDVW
Username: Atoneman
Post Number: 9
Wow, thanks alot guys, this really helps. Let me ask a quick question without sounding stupid, but I thought to setup a speaker box, you just wire them to the pre-existing wires to the car speakers? That's unless you do setup with a amp, then of course extra wiring will be required? Is this wrong?
-Atone
Username: Atoneman
Post Number: 10
So I should be looking for something like this?
http://i3.ebayimg.com/03/i/01/9f/9d/52_1_b.JPG
I might just have to watch this item on ebay.
-Atone
Username: Glasswolf
Post Number: 2399
you NEED an amp to drive subs
period
Username: Atoneman
Post Number: 11
Okay, any ideas on what type of amp I should buy? I know one that delivers a great sound with no distortion? Any brands better than others, for a reasonable price? Let's say $150 or lower?
-Atone
Username: Glasswolf
Post Number: 2438
the amp will depend on the sub(s) you go with.
if you get a single compVR 4+4 ohm DVC sub, you could use a JBL BP300.1 amp and that'd be $99 for the sub, and $160 or so for the amp I think, and maybe $40 for the box.
