What subwoofers would be the best? for $400.00 total. I need 3-4 12" subs
Username: Bradrgilman
GALvEStoN , Tx Usa
Post Number: 49
I have a reg cab silverado with the max size for a box being 57"x10"x16" or about 4.5 square feet. What would be the loudest subs for $400 total. I have 2 kicker 1200/1 amps and can get a custom box for real cheap. Should, I get 4 CVR 12's for $300 in a sealed box, 3 L5's in a ported box, 2 L7 12's in a ported box. I could also fit 1 15" l7 in a ported box or even 2 l7 15" in 2 sealed boxes or 1 odd shaped sealed box.
So, let me know what would be the loudest for the price?
Thanks
Brad
Username: Baseball1187
Columbia, SC
Post Number: 304
if you have those amps you have a lot of choices
do you want SQ or SPL?
Username: Ford_on_20s
Jacksonville, Florida Us
Post Number: 205
if your going for loud id go with the 2 12'' l7's out of the ones you named
GALvEStoN , Tx Usa
Post Number: 54
whats the diffence SQ or SPL
Post Number: 207
sq is sound quality and spl is loudness
Post Number: 208
with those amps id go with 2 15'' l7 if you want loud and dont care about having great sq
GALvEStoN , Tx Usa
Post Number: 55
okay! would that be louder then 3 L5 12" in a ported box
Post Number: 209
yea go with the l7's
Username: Nutty91rs
Bloomington, Indiana USA
Post Number: 326
I think the 3 L5's 12's will outdo the pair of L7 15's, but you won't be able to run both of those amps to the 3 L5's unless they're strapable
Columbia, SC
Post Number: 308
get a 15" MT from the RE sale, dual 1 ohm coils. Put one amp on each coil. Ported box around 35-40hz. It will blow you away.
