I have a 97 dodge neon. the front door openings are 7", the dash opening are 3.5", and the rear deck is 6x9s. i am thinking of putting a component system up in the front, and putting the tweeter in the 3.5" opening. im planning on spending around 200 on just the front speakers, 300 at the most. what do you suggest for the front and the rear, and what amps. i already have an optima, and plan on upgrading the big 3. thanks alot in advance
personally, i was looking at infinity kappa perfects and jl audio xr650's. they both run around 200 on ebay which would still leave you with some money to get an amp for them. from what ive been told upgrading is only worth it once you amp them. im sure theres plenty of other good componets out there, just the ones i was looking at.
