Good Amp for (2) KAPPA PERFECT 12.1D?
James Palanza
I'm looking for a good amp to push two of those. At 350watts RMS, should I get an amp that can push atleast 400 to each sub? I was thinking a
Infinity
REF611A
600 Watt Class D Subwoofer Amplifier
But thats only 657 watts RMS x 1 channel at 2 ohms.
The next step is:
Infinity
REF1211A
1200 Watt Class D Subwoofer Amplifier
But thats over 600+ Watts RMS to each sub, too much. Plus, I think I would need a bigger alternator for that. Any suggestions? Should I get two of those 600 amps? Bah any insight is appreciated. - Thanks.
Username: Rovin
Trinidad & T...
Post Number: 3492
thus sub
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14490
buy a 2chan amp that does 400wrms @ 2ohms on each channel
or a 1000wrms @ 1ohm mono amp ......
James Palanza
Well, wouldnt this amp work well for two of those? It can be taken to 2 or 4 ohm.
Infinity
REF1211A
Username: Rovin
Trinidad & T...
Post Number: 3550
even if that amp can do that thats a risk of blowing your subs .........
Username: Loudon
Post Number: 310
dont buy that ampp... infinity amps are garbage
Username: Homegrowncam
Watauga, TX United States
Post Number: 126
Well those subs can take a peak power of 1600 watts or something like that. you arent suppose to go by that by I am sure that powering two of those by the 1211a will be fine. hey mike why do you think infinity amps are garbage?
