RE 12.1
Username: Cenus
Hicksville, Ohio Usa
Post Number: 770
what is the biggest gauge of wire this amp will fit, cause my dad can get 2 gauge wire really cheap but i wanna make sure that it will fit.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1748
i'm 90% sure its built for 4ga.
but, you can buy wire gauge reducers or disto-blocks on ebay.
Username: Cenus
Post Number: 771
ya i'll just have to hope 2ga can fit if not, um well i'll think of somthing, and is $39 a good price for 25ft of 2ga wire cause thats the price my dad can get it for, i know i'm not going to use it all but i figure i might as well upgrade the big 3 while im at it.
Username: Thigpen
RVA, Va Usa
Post Number: 331
david from REaudio on some other forum said that it will fit 2 guage wiring... someone else also said that when they called RE told them to use 4 guage wiring.. i guess it fits both. ill be able to tell you in about a week because i have one coming along with 2 12" SE's :-)
Username: Thigpen
RVA, Va Usa
Post Number: 332
http://forum.soundillusions.net/showthread.php?t=56674
thats one link. theres plenty of them where it says 2 guage will fit. if you scroll down teamPSI is the guy who works at RE
