Like
Amp for audiobahn 1000n
Username: Bblefty33
Post Number: 14
what would be a good amp to fire off to of these guys? budget is medium
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 2858
specs of the subs, and vc config
Username: Cadillacdb
Houston , TX
Post Number: 273
Are those the AW1000N Audiobahn Subs ? if they are then they are 10 inch subs an 4 ohms DVC an 600rms each ... if your budget isnt all that large then go with somthing that puts out around 1200rmsX1 at 1 ohm ( mono amp ) an wire the subs together to present the amp with a 1 ohm load.. get back to us with how much you want to spend an do you already have the subs because if you dont im sure the guys could also help you choose much better subwoofers well if you have around 350 bucks then get a Kicker KX1200.1 off ebay to push those with
Facebook
Shop Related Deals
Directory
