Ohm question
Username: Ilyawizard
Post Number: 9
It says on a sub that it uses 4 ohm. Is it possible for a sub with 4 ohm use 2 ohm and would be the difference?
Username: Rovin
Trinidad & T...
Post Number: 3535
can't figure out exactly what u are saying
post that sub's model no & rephrase that question .......
Post Number: 11
INFINITY KAPPA PERFECT10.1D 10"
Power Handling, RMS: 350W
Impedance: 4 Ohm DVC
Now the amp I wanted to buy is 700WRMS @ 2 Ohm, and 350WRMS @ 4 Ohm
So I was asking if the sub could run at 2 Ohm instead of 4 Ohm. And if it can then what would be the difference?
Username: Kwrubel21
Shelby Township, MI United States
Post Number: 24
it's a dual voice coil, so it should run at 2 ohms automatically.
you could but another sub and wire them parallel parallel and theyll be at 2 ohms
not anon
kevin are u h0mo or stupid
Username: Kwrubel21
Post Number: 25
probably just stupid. but i was taught that 2 4ohm voice coils means divide the ohm load by 2 and that's what they're running at.
Username: Themax96se
Post Number: 94
This is annoying and funny at the same time. Unregistered guests are the idiots.
Post Number: 12
Ok...I think I got it. Getting some flashback from high school phisics class on resistance.
Basically if I get 2 350WRMS 4 Ohm subs and connect them in parallel, then I'll be able to use 700 WRMS amp at 2 Ohm, right?
Username: Young_james
Post Number: 392
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=3+woofers&WoofImp =Dual+Voice+Coil+-+2+ohms+x+2&image.x=25&image.y=8
All your questions answered! Just fool around with different configs.
Username: Kwrubel21
Post Number: 26
thank you young james.
Post Number: 13
Thanks James...very good tool. But here's another question. Is there difference in quality b/w 1 Ohm load and 4 Ohm load?
Username: Rovin
Trinidad & T...
Post Number: 3537
no real audible differences ...
however amps that put out alot of power @ 4 ohms are very expensive when compared to amps that do it @ 2 or 4ohms ......
