Diamond D3s vs Infinity Perfect 6.1
Username: Frkkevin
Fort Worth, Texas US
Post Number: 41
Which of the two is better? They will be power to there RMS maybe a notch over. They have to keep up with two RE SX 15s running in the back off 2400rms so the mids and highs have to be loud. I'm limited to the door speakers in my truck so it will be the 6-1/2 component setup. Anything be better for the same price range? Help is greatly appreciated!
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 581
Diamond D361i=60 watts @91 dB 4 ohm (6.5")
Diamond D971=200 watts @92 dB 4 ohms (7")
http://www.diamondaudio.com/
Infinity Kappa 63.7l= 75 watts @95 dB 2 ohms (6.5")
Infinity kappa Perfect 6.1=100 watts @90 db 4 ohm (6.5")
http://www.infinitysystems.com/caraudio/default.aspx
Username: Vinnyqh
Portland, OR
Post Number: 46
If you are going for SPL i would go with infinity, but for SQ defiantely the diamond hands down.
I would HIGHLY HIGHLY recommend the diamonds.
Username: Homegrowncam
Watauga, TX United States
Post Number: 124
SPL out of a set of components, why would you want SPL out of them.
Username: Vinnyqh
Portland, OR
Post Number: 56
Sorry, my bad on that comment, dont' know what i was thinking. If you want a lot of highs then go with the infinity's.
haha at myself. :-)
