Setup in hatch
Username: Reseaudio
Post Number: 34
I have a 93 ford probe and i need to know what the best setup for the subs is. Should i use 2 seperate boxes for my Re 15s or one single box? Port direction? Sub direction? Are there any custom ways to setup my subs in there? Thanks again.
Sploosh56
If I was you I would put them in separate sealed boxes. As for sub direction it's is gonna depend on the type of bass you like. If you point the subs toward the trunk the bass will be louder and a bit more boomy. If you face them toward the front the bass will be smoother. If you want to putthem in ported boxes it is basicaly the same thing. If you have a lot of trunk space make ported boxes they will give you the loud bass that bumps hard.
Username: Jchevy91
Post Number: 18
If i were you, i would put them in the same sealed box. It will make the SPL and SQ better. Thank you.
