Silver Member Username: Biggyg9712Post Number: 136 Registered: Sep-05 | hey, im looking preferably for a 12 inch sub. its gonna be powered by a kicker kx600.1 amp. the amp gives out 600 wrms at 2ohms. im looking for a sub that would match up with this amp and sound really good. i had 2 12'' kicker cvr's hooked up to it but i sold those, looking for a sub that will produce the loudness that those did. ive been looking around and noticed that people like the re se, alpine type-r, and eclipse aluminum, which is the best buy, or are there any other suggestions? |
Gold Member Username: RovinTrinidad & T... Post Number: 3327 Registered: Jul-05 | "other suggestions?" - try Diamond audio or some mmats subs ...... |
Silver Member Username: Biggyg9712Post Number: 137 Registered: Sep-05 | can u give me some model numbers on whats good out of those brands? and how much do they usually cost? |
Gold Member Username: RovinTrinidad & T... Post Number: 3330 Registered: Jul-05 | well check out the tons of brands found @ www.woofersetc.com .......... |
Silver Member Username: Biggyg9712Post Number: 139 Registered: Sep-05 | what do u think is louder, the eclipse aluminum 12 or the type-r 12 |
Bronze Member Username: Pat99Post Number: 20 Registered: Nov-05 | try the rockford T112D2 |
Silver Member Username: CenusHicksville, Ohio Usa Post Number: 717 Registered: Jan-05 | i would take the AL, u might look into RE se subs. |
Silver Member Username: BlainewPost Number: 179 Registered: Nov-05 | get 2 pioneer premier TS-W3004SPL's.....they are 1000 watts RMS each ..and only 100$ each on ebay...they are good subs 2076_4061_153020681%2C00.html,http://www.pioneerelectronics.com/pna/product/deta il/0,,2076_4061_153020681,00.html |
Anonymous | """hey, im looking preferably for a 12 inch sub. its gonna be powered by a kicker kx600.1 amp. the amp gives out 600 wrms at 2ohms""" so he can't do 2 of those pioneers |
Silver Member Username: BlainewPost Number: 181 Registered: Nov-05 | wow..i dont know why i typed that..sorry haha |
