Wiring idea/question
Username: Blainew
Post Number: 166
if u have a dvc sub and a 2 chanel amp...what would happen if u wired each neg. to a neg on the amp and both pos. to each positive on amp..can u do that
if 4 example your amp does 250wrms x2 @ 2ohms & u have a 500wrms 4ohms dvc - then attach 1 chan / VC ...
Username: Solacedagony
New Jersey US
Post Number: 663
You can do that, but if you're wiring at 2ohms, then you'll need a 2 ohm DVC sub.
250 rms x 2 @ 2 ohms on a 2 ohm DVC sub.
Also, please stop posting 20 copies of each message. Post it in the correct section and let people respond to it. People get annoyed when they take their time to reply and then see there's another 2 copies of the same message across the forum.
