500$ budget
Username: Scottrschmitz
yeah i just got my car and im looking for a qaulity but not to pricey system to start out with anyone got any sugestion for a qaulity set up for 500$
*has anyone ever bought anything on ebay because i was looking at some stuff but is it reliable should i buy off ebay
i listen to rap if that makes difference
Username: Young_james
Post Number: 268
there's nothing wrong with e-bay if you watch the seller's feedback. Make sure they have a score of 95% EXTREME LOWEST and up. Also check for any recent negative feedback. Double check on shipping costs too.
As far as getting a system for $500, i'll leave that up to Rovin. He's the champ when it comes to putting together budget systems.
Post Number: 269
btw, was the $500 just for a sub(s) or amp? Or sub, amp, deck, speakers, wiring, and box?
sub and amp, and the wiring i guess cuz that cost 100$
so really like 400$ on the system
Username: Thigpen
RVA, Va Usa
Post Number: 297
save up until you have more than 400 or else youll buy something now, not be happy, and then have to save up from 0 for something you like.
Username: Baseball1187
Columbia, SC
Post Number: 229
wiring - knukoncepts 4ga - around $40
box - build one $25
subs - Alpine Type R, Resonant Engineering SE
amp - Kicker KX600.1
if you can fit a 15" in a ported box... will be VERY loud. that should all be around $500, if not less... you can get the RE SE 15" for $167 on Dec. 5th
ware can i get that 15" on dec 5th
Username: Rovin
Trinidad & T...
Post Number: 3310
or buy Chauncey's $175 type X & a Hifonics bx1500d amp .......
Username: Rovin
Trinidad & T...
Post Number: 3311
Thomas White (i think) has that Hif 1500 amp for $150 + s/h
can't go wrong @ all with that deal ....
Post Number: 282
that would get insanely loud. That's an excellent price, considering that it was only used like 4 minutes or something
Post Number: 8
well i think im goona buy 1 12" infinty subs so would that amp work good with those
Columbia, SC
Post Number: 237
need more details on that Infinity sub to recommend an amp!
Username: Themax96se
Post Number: 73
If you mean the infinity 1242W, it may not be a bad idea. I was actually just looking at these, and you can buy them at your local CC right now buy 1 get 1 free:
http://www.circuitcity.com/ccd/productDetail.do?oid=119551&c=1&cm_re=main%20marq uee-_-Buy%201%20Infinity%20subwoofer%20get%201%20free-_-Infinity%2012
For under $120, your getting two decent 12" subs together 600 RMS. Go get a dual encl. for $40, and maybe a audiobahn or hifonics amp for under $175.
Speakers: $120 for 1242W @ your local Circuit City
Enclosure: $40 (I get mine at pawn shops for $20-40)
Amp: $138 AUDIOBAHN A8002T @ eBay
- choose 2 ch amp, for bridging @ 4ohm
$120 + 40 + 138 = $298
I second using knukonceptz wires from eBay... you can surely get these wires and some other things you may want to add to your system for the other $200.
The buy on the Type-X and hifonics is not a bad idea either. BTW, I make some of the best budget systems as well. I actually specialize in them, since I started out myself trying many of my own.
I got a few things priced to sell:
Amplifiers:
JL Audio e4300 - $230 NIB (NEW in Box)
JL Audio e1400D - $250 NIB (NEW in Box)
Phoenix Gold Tantrum 500.2 w/LPL44 bass knob - $150 (Like New cond.)
In-Dash CD Player:
Alpine CDA-9807 - $125 (Good Cond. no rem)
Will eBay these items soon as I take pics. Interested?
e-mail: themax96se@yahoo.com
