New system
Username: Malcantry
Post Number: 7
ok im looking at putting a new system into my civic and know how im going to do my subs and now going to work on the speakers.
ive got 6 1/2's in the front
and 6 x 9's in the back
few questions for yall..
what am i looking for as in how many ways it says the speakers are
(i.e. 5 way 2 way or 3 way speakers?)
and the speakers i was lookin at were
Pioneer TS-G1640R 6.5" 2-Way Speakers
and
Pioneer TS-A6991R 6"x9" 5-way Speakers 6"x9"
ill also need a seperate amp to run these correct? if so can you direct me towards one?? dont want to spend more then 200 er so..
lookin for the best deal for a cheap price
thanks
Username: Malcantry
Post Number: 8
ok screw the pioneers.
ive decided on alpine..
Alpine SPS-690A 6"x9" 3-way Speakers
Alpine SPS-170A 6-1/2" 6-3/4" 2-way Speakers
now.. can yall help me decide on an amp??
Username: Rovin
Trinidad & T...
Post Number: 3181
No subs - just those alone ????? Alpine has some good 4 chan amps .......
do spend some extra $ & get component speakers instead - it'll sound alot cleaner ......
Username: Malcantry
Post Number: 18
INFINITY REFERENCE 7541a 4-CHANNEL AMPLIFIER
520 Watt 4 Channel Amplifier
SPECIFICATIONS:
Power Output:111 watts RMS x 4 channel @ 4 ohms and 1% THD + N
278 watts RMS x 2 channel @ 4 ohms, 14.4V supply and 1% THD + N
Signal-to-Noise Ratio:81dBA (reference 1 watt into 4 ohms)
Dynamic Power:164 watts @ 2 ohms
Effective Damping Factor:6.315 @ 4 ohms
Frequency Response (-3dB):10Hz to 100kHz (-3dB)
Maximum Input Signal:5.5V
Maximum Sensitivity:230mV
Output Regulation:.088 dB @ 4 ohms
this will push around 111W rms @ 4 ohms correct?
i like the specs on this amp and have heard good things about infiniti.
would i be a good amp for the setup i want?
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 457
yeah, get 6.5" components in the front and forget about the back. put a sub in the back.
