Just wondering
b1gj0033
if the internal box volume is what is recommended, what is the worst possible thing that could happen? just wondering because i don't want to screw up building a box
Los Angeles, CA USA
Post Number: 1065
do you mean if you don't build the box to recommended specs what is the worse that can happen?
the subs won't sound good. if you build it too big then you might even damage your subs.
b1gj0033
gotcha just wondering so i don't screw anything up
