"FMOD" Low Pass Filter.. Which One?
Username: Slide
I have an old Rockwood 200watt amplifier pushing two 8inch kicker Comp 8c's. The amplifier doesn't have a built in Crossover so I plan on buying a FMOD Low pass inline filter....
... but there are a ton of different kinds. 50 HZ, 100 HZ, 500 HZ etc etc.
Which one would make sense to purchase for this setup? I just want to get rid of the Mid's and Highs coming through the Subs, but I don't understand the HZ measurment.
Any help is appreciated.
Thanks,
Stupid old equipment...
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 1633
somewhere between 60-80Hz is good.
you may want to get a better amp, too.
rockwood is crap.
those C-series subs are great though.
Username: Slide
Clinton Township, Mi
Thanks,
How does the HZ rating work? I guess part of my question would be, why is 60-80Hz good?
I know what you mean about the amp, but I've been using it for 7 years. heh... I bought it used so I wouldn't be surprised if the thing was close to 10 years old.
It still does it's job without much complaint.
One day I'll get something better to push the Comps.
Username: Glasswolf
Post Number: 1638
Hertz are cycles per second. a measure of frequency.
didn't you take science in school?
60 to 80Hz is about where you go from subs, to mid-bass. if you cross over the subs any higher than 80Hz, you'll start to hear vocals in them, and they'll begin to sound muddy, and not as tight or hard hitting.
Username: Slide
Thanks again,
Yeah, science was a treat for me... and also 6 years ago... heh.
I'll be doing a bit more research on frequencies in the car audio department, but this quick bit of info has really helped me get these parts on order, so thank you.
Username: Glasswolf
Post Number: 1643
check out www.bcae1.com
that site has great in depth stuff on every aspect of car audio.
should tell you everything you want to know
if ya don't find it there or don't understand it, get back to me here
Robert J
if you here voice coming out of your sub and your amp is already set to 65 hz then what do you need to do
