Cheap radar dettector?
Username: Hondarider
Glidden, Iowa U.S.
Post Number: 188
whats a good radar detector that is less than $150?
Glidden, Iowa U.S.
Post Number: 189
is this a good one for the price http://www.ewis.ca/onlinestore/scripts/prodView.asp?idproduct=1203
mutt
Pull into my driveway in the middle of the night running from the cops....you'll get a .40 cal slug in your head!!
What a dipsh*t
2fast4u
Don't get a Cobra, they suck for range.
Just take a look at these radar detector tests or anywhere else for that matter.
In my opinion THIS ONE is pretty good for the money, and you can get it at radio shack. Otherwise look into the Whistler Pro58 or Pro73...
Username: Southern_bass
Jacksonville, Florida U.S.
Post Number: 67
got mine at radioshack..its nice
Need to Register?
Forgot Password?
Enable HTML code in message
