Please help
Username: Blainew
Post Number: 72
i have a 2 channer amp..its not bridged and its taking a 4 ohm load...now i have two 300 watt tweeters....and i just wire the tweeters right into the amp...right where the sub wires are wired in..is there any chance ill hurt the amp...
Username: Blainew
Post Number: 73
i mean .."can i wire the tweeters into my amp where the sub wires go in??"
Username: Rovin
Trinidad & T...
Post Number: 2894
300w tweeters ? - u mean max not rms .
what amp,tweets/subs are u talking about - post model nos .......
Username: Blainew
Post Number: 75
yea max...but anyways..its a soundstorm f2800 amp...i dno what kind of tweeters..i just wanna know how to wire them..b/c im running my system with stock speakers and i need better highs..and i dno about ohms in tweeters but if i wire them to my amp i dont want the ohms to change and then my amp to burn out
Username: Rovin
Trinidad & T...
Post Number: 2899
u may quicker burn out your tweets than your subs if u are pushing the same wattage to both ...
Username: Blainew
Post Number: 76
how do i wire them though???..will it change the ohm load..
what do i do to get the tweeters working??
Username: Blainew
Post Number: 81
anyone know???
