How
Username: Graphix1
Santa Rosa Heights, Arima Trinidad & T...
Post Number: 73
If you were to use a car sub for home theatre use what could you do to get it to work/sound like a home sub,build a bigger box?or maybe build something around it?Is it even possible?
Username: Nutty91rs
Bloomington, Indiana USA
Post Number: 218
Yes it's possible, a larger lower tuned box will help as long as it's not tuned below the sub's FS.
Username: Graphix1
Post Number: 74
If its tuned to fs exactly in the same small box would that help?
Username: Nutty91rs
Post Number: 223
Yes it would help. Your room has a much lower resonant frequency than a car does so you need more reinforcement down there. Tuning a box to a subs FS is going to make the output at that frequency very strong but it's going to have a big peak, probably not a bad thing in your home.
