Check this out
Username: Terry6405
Sullivan, IN US
Post Number: 83
just tell me which you think is better
http://sonicelectronix.com/item_5143.html
or
http://sonicelectronix.com/item_3046.html
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 539
The bottom one is louder (90 dB) and it is a better designed set.
Better diaphragm, surround, more dynamic frequency range (although I doubt that that 5 1/4" driver is going to reproduce a cutoff of 30 Hz lol).
The top one is a low end unit.
Username: Terry6405
Sullivan, IN US
Post Number: 84
how do you think the CV would compare to the infinity refrence5000cs?
should i just go for the infinity?
i heard they are really good once you break them in
