Paralell in sealed box
Username: The_disciple
Post Number: 26
How can I wire my subs paralell in a sealed box? The only way I can think of is to have the wires from the positive and negative of one speaker coming out of the speaker hole of my box, then doing the same for the other sub, and screw the subs in place(with the wires coming out of one sub hole, and into the other). Would that work?
Username: Rovin
Trinidad & T...
Post Number: 2732
what subs & do u mean 2 subs in single or double chamber box ?.......
Post Number: 27
It's a double chamber box. Subs are Infinity 1230w
Username: Rovin
Trinidad & T...
Post Number: 2736
u could install 1 connector terminal on each side/sub & run your wiring to your amp to suit
http://www.the12volt.com/caraudio/woofer_configurations.asp
