Installation help:
Username: Teighto
Hi,
this is for all you Tech Heads !!!!
i have just purchased this player off of ebay
http://cgi.ebay.com/ebaymotors/E191-7-Motorized-Color-TFT-LCD-TV-Monitor-DVD-Pla yer_W0QQcmdZViewItemQQcategoryZ38650QQitemZ8012584987QQtcZphoto
It arrived this morning and im trying to fit it at the moment i have done all my ICE installs before on my own and have had no probs fitting anything, but on this particular model there is one wire that i cannot figure out what it is. i have tried reading the manual but i cant read japenes/chinese !!
Here is the jist of what i have done already,
this is what comes out the back of the dvd unit:
red - acc
yellow - battery
black - ground
blue - amp on/off
white - ground for Park
i have a green one which i have no idea what it is for ??? any ideas
i have a seperate unit that the speakers come out of and what you input/output various equipment i have done the following on this.
yellow - battery
black ground
orange - thought this would be illumination but it only comes from the seperate unit and says auto ant ??
brown wire with amp ctrl on but thougt the blue one on the other unit was this ??
i am very confused so any help is much appreciated
Chris
Username: Tjmutlow
Post Number: 178
Try seeing if that unit will work without it being hooked up, if not try ground it.
MikeStrong
The orange wire on my unit says illumination
